Originally Posted by O-cha
Nate I'll send send one to you when after a bit of feedback from darkstar but keep in mind while you had the code that we are talking about you also had codes that indicate a bad O2 sensor and should not be there.
Ok, however you think works best. I have a new o2 sensor that I was planning to install when I removed the headers and the sim, going back to stock. Obviously would be much easier to replace the sensor and the new sim if you thought that would solve the issue. I could go ahead and do the sensor replacement now if you think that would be a better diagnostic with the new sim. Let me know. Thanks
p.s. keep in mind I drive the car ~300 miles a week highway so I'm a good source for feedback on this
