Originally Posted by Michael9218
Power is one the last things you should be looking for.
1. Weight
2. Chassis (bearings/bushings, suspension, setup)
3. Tires (if you aren’t running a sticky DOT slick than don’t waste your money on power)
4. Aero (more grip)
5. Power
Oh, I agree with the priority and I didnt intend to chase power this early in the build, but then a rebuild hit me and if parts need to be replaced anyway it’s hard not to spend now for what would be bigger dollars later when the engine is back in.
