Originally Posted by Starscream
So if you had the reverse camera in the "camera" input,
and another camera (lets say front mounted) in the video input with a separate switch to either ground it or power it,
your saying that will work?
So if you mounted a switch in the car, flipped it and the front camera would come on,
and the same when you hit reverse the rear camera would come on,
When you look into these modules it says "camera" and "Video" as inputs, But in theory you could use 2 cameras if you wanted?
I would love that
Correct - the 2nd device is triggered by a remote wire which is normally found on most +12V electronics.
If using a portable device like an iPod - a switch must be mounted in order to activate the input.
