      05-04-2019, 08:01 AM   #5
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
On my E90, I've done all the gaskets in the N52 that eventually leak. For the valve cover and oil pan gaskets, I used original BMW gaskets along with a thin coat of Permatex Ultra Black gasket sealer on both sides of the gasket. Both are leak free 3 years and 100,000 miles later. For the profile gasket in the oil filter housing, I just used the original BMW gasket with no gasket sealer.
