Excessive outer edge tire wear
I’m getting excessive outside edge wear on front tires on track and would love some advice. I’m running 3.5 front 2.5 rear camber. These are re71r’s, hot pressure 36. Jrz rs pro coil overs, GC camber plates. Picture is the front right (passenger) after 5 track days. As you can see, edge is EOL, while rest of tire is barely worn. Driver side about the same. I was previously running TCK D/As with 3.7 camber and the wear was a bit better, but still not good. Note that I’ve already had the fronts swapped side to side once. I think there may be three reasons/solutions...
1. More camber? The GC plates are maxed out so maybe put in camber washers and go to 3.7 or 3.8?
2. Square setup to reduce push and allow tire rotation? Not that rotating will fix this problem—just lets me wear out all 4 tires faster!
3. Am I entering corners too fast and pushing? I don’t think so, but are my tires telling a different story?
Suggestions?
