Sounds like the difference in wear isn't drastic and car drives well. If the alignment pins on the front struts haven't been pulled, on stock suspension you aren't running more than 1 degree of negative camber, so you can rule out "too much negative camber" as the reason. It could be an issue with too much toe-in in that case, but I would just wait until you put on the new suspension.
