      10-11-2010, 09:31 PM   #1
jbh
jbh's Avatar
18
Drives: 2007 Z4M
Any suggestions on alignment for street/autox with Turner camber bolts?
I just installed the camber bolts/shims ($15 kit) from Turner. Now I need to get it aligned. I run Autox events 2-3 times a month and street drive the car 3-4 days a week. I have a second set of wheels with Hancook RS3's for autox (245 square) and have my regular wheels I street drive on with stock tires and stock stagger.
I was thinking of running -2.25 to -2.50 front camber if I can get it with the bolts to help reduce understeer and promote better tire wear for events (I know I will wear the insides of my street tires a little) and keep it drivable on the street without any bad effects. I don't know what to run in the rear with this setup. Also not sure about the toe but .05 seems to be popular.
I am open to any suggestions for someone who had done something similar as far as the specs, I need to tell the shop what I want.
