      09-07-2021, 03:31 PM   #83
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
Originally Posted by kk2 View Post
I’d say the adjuster is near the middle. I’m running a 265/35/18 on a 18x10.5 +22.. about -2.5 degrees of rear camber with rolled fenders. There’s not really any gap in the rear, it’s pretty flush. About 13” from the center of the wheel to the fender lip.
No helpers, but I don’t need them with my setup.
Thank you, that sounds right.
I am running 14" from wheel centre to fender lip. Want to be about 13.5"
What spring rates are you on?
I have been told that spring rate makes a big difference to ride height. Someone said going from a 400lb to 500lb spring they needed a shorter spring.
I'm planing to use 500lb springs in the rear.
