Originally Posted by ANILE8
Thanks, I am leaning towards a 5" spring now.
Whereabouts is your adjuster set with a 5" spring, all the way up, middle or bottom?
What size rear tire are you running and how much of a tire to fender gap do you have?
Are you running helper springs? At full droop, I measure 7.5" so if I went with a 5" spring I am sure I would need helpers to stop them flopping around when jacked up.
I’d say the adjuster is near the middle. I’m running a 265/35/18 on a 18x10.5 +22.. about -2.5 degrees of rear camber with rolled fenders. There’s not really any gap in the rear, it’s pretty flush. About 13” from the center of the wheel to the fender lip.
No helpers, but I don’t need them with my setup.
