Originally Posted by rsutoratosu
I always removed my seat without the battery connect to avoid the airbag light.
Basically I want to remove the seat to clean the carpets (bissel steam cleaner) & leather itself. Since its winter, it'll take some time to dry.. if I drive around without the seat on, will it trigger some airbag light issue that I can' t disable once I put the seat back in ?
Thanks in advance
Yes. you will trigger airbag light and they will stay on.
If you have coder, you can easily turn them off.
I don't know whether if you turn off the airbag on the passenger side before you take out the seat, it'll still trigger though.
