Originally Posted by 519.E82
To my understand it is a 16610 Black DLC like you said, but it was a gift and is my first Rolex so wasn't sure how to 100% verify/check its authenticity
Ah, got it.
You could take it to a Rolex AD and they should be able to open it up and check the movement along with removal of the band to check the serial number a series number.
However, they won't be able to contact Rolex to check the legitimacy. The only way you can do that is if you send it to Rolex for service. Then it will be checked to see if it's legitimate and if it's stolen. If either of those cases are true, you'll never see your watch again.
It's weird, it's the only way to verify a Rolex. It seems like they could charge you a fee to verify your watch prior to purchase.
