Originally Posted by M-Cast
Well, we finally figured out what was going on with the throttle actuator. The Dinan throttle bodies were not set correctly by the manufacturer and the fail-safe was cutting power and not allowing the car to complete the startup sequence. Since they specifically tell you not to mess with the settings or it will void the warranty it makes this hard to track down.
The next step is getting the new Epic Alpha tune flashed to the ECU and then off to the Dyno Next week.
Great work, looks really nice. Can you take a shot of the snorkel interacting with the intake scoop in the front bumper.
Also what are you running exhaust wise?
