I really hoped it was the by-pass since you'd been fooling with it.
If the lines appear short, check to see if you cut all of the ties. It should fit in the area in the trunk behind the driver without issue.
I'm hoping your leak isn't caused by a failed hinge lifter. That's a bigger & more costly repair. However, there are outfits in the state of Washington and Florida which will rebuild them.
