Picked up this car in May 2016. Within a few weeks of the hot weather the coilovers started to groan and squeak especially went turning up driveways. Took the car into the shop and they sprayed lube and the noises all went away. Shop said it has a lot to do with the dry hot weather and the dirt/grime that gets in there.
Anyways the noise is back again. Anyone else have this issue ?? I'm thinking that the entire coilover assembly has to be removed and cleaned up...... maybe ??
I have never had this with any other coilover setup on any car in the past. Coilovers are BC's.
