Alright, slight change of plans. I went with the H&R 27mm bar for 3.0si. Those of you who used this bar, being that it is same diameter as the Z4Mm bar, would you say the outer most hole (there are only two holes on the bar) gives the same stiffness as Z4M bar? Or, is it already stiffer using the outer hole? I'm not planning on going inner hole yet.
Doing one thing at a time. With an LSD coming in next week, I'll start with stiffer front bar and LSD, and go from there. I can remove the rear bar or install the 18mm bar, but will leave that for last resort. The car rotates so well and handles great that I don't want to mess with a too much of a good thing.
