Bringing this back since I pulled the fuse on my headlight washer after trying to source parts to fix that "hole" of the missing cap. Fuse #40 is what I pulled. I tested out with several pulls of windshield cleaning and headlight on, the headlight washer doesn't pop-up any more... Finally..
While I was looking at the fuse box and the diagram, I realized that my #4 has a 20amp fuse half way inserted. According to the above diagram, #4 is not used. So I pulled that #4 fuse.
I crank the engine to make sure everything is in working order. Car turned over, engine started and everything seems fine. In just about 1.5 second, it dies. So I tried again. Car turns over, all is good, press the gas pedal to rev the engine, it just dies. Put the #4 fuse back in. Everything works normally.
What does this #4 fuse do?
TIA,
