Prep day with the Z4 3.0si
Thought this would give you guys a closer look at the Z4 Endurance car. we still have a few items to finish her up, these are great cars for those looking for reliability and lower consumables.
Weight: 2705 lbs
WHP: 268
Cost to Build: $55,435.95 (*not including labor)
Chassis
2006 BMW Z4 E86 3.0 si $10,000.00 Est
Suspension
MCS 1 way dampers $2,750.00
Ground Control Sway Bar Kit $699.99
Ground Control Coilover Kit (Springs, Mounts Links) $839.99
Ground Control Race Camber Plates $419.99
AKG Lower Rear Lower Adjustable Control Arms $280.00
"SyncroDesignWorks RTAB's, Rear trailing arm bearings" $265.00
Rouge solid Inner and outer trailing arm bushings $150.00
AKG Rear Shock Mount Set Aluminum – Spherical Bearings 12mm $150.00
AKG - Differential Mount Bushings, Poly 75D – BMW E46, Z4 (Non-M) $140.00
Welded in strut tower reinforcements $500.00
Upper Strut Mounts $250.00
Ultra Racing Lower Rear Strut Mounts $250.00
AKG - Front Control Arm Bushing Set (66 Mm), Poly 75D $80.00
Drivetrain
AKG Motor And Transmission Mounts, Poly 75D $180.00
Syncro Custom differential 4 clutch ramp 3.73 gear ratio $3,400.00
Bimmerworld Differential Cooler $659.00
NB Engineering Shifter $399.00
AKG Selector Road $150.00
JB Lightweight Flywheel and Clutch Combo $899.99
Aluminum Pedal Upgrades $125.00
Mason Engineering Clutch Pedal
Rouge Barke Bushing upgrades $320.00
Braking
Stoptech slotted Rotors $300.00
Stainless Steel Brakelines $150.00
Hawk Pads $600.00
Brake vents and backing plates $350.00
Wheels & tire
APEX 17x9.5 forged wheels $1,550.00
Hoosiers $1,350.00
APEX 18x9.5 ARC 8 Flow Form wheels $1,000.00
Yokohama Avant 052
Exterior
M front bumper with VRS and APR splitter $1,500.00
M Aero Rocker Panels $750.00
Lexan Rear and side windows $650.00
APR 250 GT 61" rear wing $1,600.00
Exhaust
Active Werks Headers $600.00
Custom straight pipe $750
SuperSprint Race Pipe & Exhaust cans $899.00
Interior
OMP Halo Seat $980.00
6 point harness $450.00
OMP seat mount $150.00
Carbon Floor pans Driver and Passanger $325.00
Bimmerworld floor mounts $150.00
OMP 330 steering wheel $299.00
OMP hub and quick release $550.00
Cool Suit Kit $565.00
Helmet Blower $325.00
Harness Thinning & Rainlights $1,250.00
Safety
Full Cage $3,680.00
Fire System $468.00
Inner Driver Safety Net $180.00
Driver Safety Nets $350.00
Engine
Epic Tune $998.00
Kassel Tune $900.00
AFE Cold Air Intake $450.00
Dinan Larger Throttle Body $925.00
Modified Intake Lift Valvetronic Supports (MILVs) $300.00
Bimmerworld baffled oil pan $1,750.00
Cooling
Upgraded Silicone cooling hoses $225.00
Replacement of water pump & thermostats $500.00
Differential Cooler Bimmerworld $650.00
Mishimoto Oil Cooler Kit $300.00
Custom Radiator Shroud for air flow $150.00
Zionsville Race Cooling kit ( radiator, overflow tank, electric fan and shroud) $1,600.00
Electronics
Braille Battery $345.00
AIM DL2 Solo with OB2 Upgrade $699.00
AIM SmartyCam 2.0 $1,100.00
Mylaps X2 Transponder $239.99
Motorola CM300 2-way radio $325.00
Battery Aux Cut Off Switch $40.00
Start and switches $85.00
