Originally Posted by dsad1
The deficit isn't created by the cut, it is created by the spending spree. Raise or lower taxes as much as you want, if you are not going to control the spending, you will always be in trouble.
Actually, it is both.
If you take in less, then you must spend less.
In Washington, they seemed to have missed that relationship (both sides).
