I think its been very well documented for owners running the Apex 18x9.5 ET35 in the front requiring 5 mm spacers (w/ neg. camber) to clear coilovers such as KW & Bilstein..
As for the supposed release of 19" SM-10 & FL-5 I imagine they will also come in the 19x9.5 ET33 configuration as the rest of the Apex wheel line?
When ran with KW/Bilstein coilovers (245/35/19?), will the additional height away from the lower spring perch + 2 mm extra clearance (ET33 vs ET35) be adequate to negate the use of a 5 mm spacer? Is that why the ET33 was designated for the 19x9.5 setups?
Looking forward to your response as it will be helpful to many prospective owners, thanks!
