      10-30-2020, 03:41 PM   #41
ga9213
Drives: 2018 X3 M40i
Originally Posted by dreamingat30fps View Post
Pretty sure that's exactly what I said.... it's not a truck for me. I need a truck that can do truck stuff.
If you want a truck to do truck stuff then it is an incapable vehicle (obviously I'm assuming since no actual EV consumer "truck" is on the market yet). if you DON'T want to do truck stuff then I'm sure it's plenty capable and based on the stats posted earlier I guess most people don't do truck stuff with their trucks.
If I was into show trucks then I certainly like the Hummer over the Cyber Truck except for it's wimpy range compared to the advertised Cyber Truck numbers and higher price.
The redneck machoism of suggesting only trucks capable of towing significant weights for significant distances are capable of doing "truck stuff" is where you've lost the point.
Trailing, camping, hauling tools, equipment, lumber, etc are all what I'd consider truck stuff since I can't do it as well, easily, or even at all with anything other than a truck.
And I don't need to spit a wad of chew out after suggesting that either.
