Originally Posted by Rated M Roadster
I'm planning to do the same thing in the same spot. Need to check if the E46 M3 backing plates fit our cars.
Originally Posted by Krypptic
I called and asked sometime ago. No one could give me a straight answer. Not sure their backing plates fit our brakes. If you have BBK you are in a different situation then the rest of us.
I bought a set a long time ago, they didn't fit.
Why are you guys thinking of putting ducts in that spot, would be easier to route from the OEM spot, just have to contend with the od shape opening.
