In my case, it's like the box is jamming the cable against the firewall. I don't think I can even rotate the cables. Also, even if I could, how does one know that the connector heads are parallel to the edge...unless you are able to see them. And, BTW, I can't lookl down to see the space between the box and the edge because the cord that releases a locked console prevents me from moving the "carpeting" away from the firewall enough to get me head in position to see down.
EDIT: Caseysc, I'm starting to get to my wit's end with this project. But before I follow the instructions on removing the box, will the whole box actually be removed? Although I did this 3 years ago, I can't remember if the whole box comes out. Looking at page 7, next to last diagram, it is ahrd to tell if a shell or the whole box comes out.
