Hello everyone!
My center console light (storage between the seats) never turns on. Door open or close. The micoswitch seems fine and so do the fuses. And, I've changed the bulb to a new tested one, with no luck.
May I please know where the connector end of the microswitch (white plastic end) goes in the event it's not plugged in...?
EDIT: I think I found a pic showing it. Can someone confirm it's the connector on the right (right green arrow)? If so, where does it go?
Thank you in advance
