      04-17-2023, 09:32 AM   #74
3002 tii
3002 tii's Avatar
2301
Originally Posted by t3ddftw View Post
Incoming audio is better for sure. Outgoing audio can be hit or miss, but ultimately I know the right combination to make it work.
Most of the time, the factory mic in later build E46s and E8xs works fine (part ending in 762), but other times it can pick up an echo of the caller which is annoying for the other party. This can be tuned out usually, but at the very worst switching to the microphone with P/N 84318380338 is the final solution. This microphone performs perfectly with the BlueBus.
Thanks!
-Ted
Is the echo based on chassis (i.e. roadster vs coupe) or options (DSP vs non-DSP)?
Follow for latest mods
