Painting the calipers G2 paint Mustang GRAY
Rear painted stock calipers, new stoptech rotors (old ones were extremely thin and completely rusted!)
Amount of gap between Z4M rotor and 335i caliper bracket.
335i pad covers rotor well on the inner radius
A bit of overlap on the outer circumference, expected since the Z4M rotor is only 345mm diameter, while the 335i rotor is 348mm
BEFORE (stock 3.0si front caliper/rotor)
AFTER (Z4M rotor, 335i caliper)
