Originally Posted by Dark Schnitzer
The OEM roofs are bolted on at 4 points with additional urethane sealant all the way around.
I'm developing a Platinum soft silicone seal to replace the messy issue with the sealants.
This way...if someone buys my products....they can easily remove the tops to re-sell or take off at anytime without the previous hassles.
Just the four bolts essentially.
Sweetness!! Since there are four bolts at each corner applying pressure why not just recommend a self adhesive weather seal that you can buy a roll of at The Home Depot?
