Ok all you need is the front braided brake line of the 135I, the caliper and carrier of the 135i and the Z4 M rotor.
Then you need to weld a spacer on the carrier "5mm" to push the caliper out a tad to accept the rotor.
It all bolts right up at that point.
The 135i carrier bolts perfectly to the z4 steering knuckle.
Working on fitting the 135i rear caliper now just haven't had much time as of late.
