Originally Posted by Phillg328i
If you have a buddy with a BMW scanner (generic ODBII codes aren't likely to help) you can review errors and/or run a module check to find the culprit. This is the best diagnostic approach in any case, as you'll have a good idea if/when you need to see an indy shop, or, if DIY'ing, you can know what you need to work on. Some scanners/coders can reprogram or program an LCM I believe, but I have not personally tried/done that.
I have known good turn switch I'm going to try first. Might have to drive it for a while to see if that takes care of the issue. Thanks !![/QUOTE]
Rodger that. Good luck!
