Originally Posted by ChaoChow
I just recently purchased a z4 m and was looking for a square setup. Does anyone know if it's possible to run a 18x9 or wider on all 4 wheels without any rubbing? I'm more concerned about the fronts rubbing on full lock.
I'm running stock suspension with stock alignment ATM.
I'm running 18" SM-10s, 9.5 et35 with 265 on all four corners. Stock suspension, but camber washers and pins pushed in for -2.5 camber. 12.5mm spacer rear, 5mm spacer in front
