Z4 and 330ci 37bz use the same transmission carrier = m3 carrier should line up with z
37bz and 420g are both the same 25" and uses the same diff (not confirmed, just from google). Z4m and m3 use the same guibo = Stock z4m driveshaft should work
Looks like the only custom piece needed will be the shifter linkage, needs to be shortened.
Question is will it fit the tunnel
