Originally Posted by Dubbedown
btw did you use the roll bar mount or handlebar mount?
Handlebar/seat post mount.
I'm wondering if you might also be able to set something up with one of the self adhesive mounts on the back side of that radiator bulkhead just behind the grill. However, the good think about the mounting I'm using is that everything is bolted/clamped on.
