I'm fairly certain my are the race version, and they don't look disintegrated as some I've seen. But, the engine sure is moving sideways more than I am comfortable with. The hot side (passenger side)'s motor mount is wrapped in thermal aluminum padding to protect from heat. The exhaust manifold and wastegate are right near it. This is the side where I kept melting the Powerflex control arm bushings (FCABS) and had to go solid FCAB. The mount it hidden do to the shielding so I don't know of it's status. Driver side looks normal.
I'll inspect these upon removal and post my findings here. Chances are they are "fine" and if that's the case, they may not be solid enough for my needs.
I agree, I don't want a 100% solid mount up there.
