      06-24-2020, 06:05 PM   #3
JimBob0047
Drives: 2006 Z4MR
Originally Posted by ZeD4Mr View Post
Is there a kit for the entire overhaul? Tabs, bolts, etc
parts cost & labor hours if you don't mind sharing?
Thinking of doing this this summer...
Here's the parts list
Beisan
Http://beisansystems.com/products.html
S54 vanos oil pump disk
S54 vanos seals repairs kit
S54 vanos sealing plate repair kit
S54 rebuilt vanos solenoid pack (optional)
S54 exhaust upper chain guide
Related Vanos Parts - ECS
(12) updated cam bolts 07129905536
(1) Vanos gasket tel:11367831938
(2) Oil return washers tel:07119963129
(2) Vanos oil return washers tel:07119963072
(1) Crankshaft chain tensioner washer tel:07119963418
(1) Chain guide mounting bolt washer tel:07119963342
(2) (optional) s54 hub spring 11367830684
(1) Valve Cover Gasket Kit - erlang http://www.ecstuning.com/BMW-E46-M3-...Kit/ES2586868/
OR
(1) OEM Valve Cover Gasket Kit -  https://www.ecstuning.com/b-genuine-...FQpMDQodjcsBxg
Labor ran me $600 with an Indy that came to
my house.
Hope that helps!
