Originally Posted by Cortes2141
Negative. Until just recently I had zero codes at all. The MAF was cut out and the wires for it wired into what ever the sensor is with the supercharger. The codes that are now throwing are a a heater O2 for B1S2 and B2S2. ESS wanted me to clear adaptation by disconnecting all 4 sensors and starting the car. After reconnecting all sensors and clearing all codes, the two downstream heater codes came back.
I use the Torque Pro app and a bluetooth OBDII.
Were you able to resolve your issue ?
