Originally Posted by ApexRaceParts
We do indeed ship to Canada!
The 18x9" ET42 and 245/40/18 wheel and tire combination works great on the front of your car as long as you are using a street tire. We do recommend pulling the alignment pins on your stock strut mounts to obtain a little bit more negative camber but this is not absolutely necessary and should be able to work without doing it.
The 18x10" ET25 and 275/35/18 rear wheel and tire combination also works great and is the maximum width we can suggest for the Z4M without any additional modifications. We can do tire packages if the wheels are a local pick up but not on shipments
I will be sending you a PM as well with a little bit more information on Shipping to Canada.
Will those specs work with a tire such as BFG Rivals?
