So cant get hold of 35 and 22 offsets for 18" volks anymore so would be great if someone here can help me to confirm these will fit;
18x8.5 ET36 5x120
18x9.5 ET20 5x120
Thinking of running 245/40/18 and 275/35 on stock suspension.
that's a quite safe/standard setup. Depending on what kind of tires you run, they shouldn't rub at all.
So you think it will be fine with 245/40 and 275/35?
Yes. They should be fine, depending on what tires are you trying to run? Any slicks or 200tw tires will have more of a square tire shoulders, and you might rub at the rear with 9.5 width at et20 and stock suspension setup.
I have ran 275 & 10 width et20 at the rear with PSS tires. They rub slightly at extreme conditions on OE setup.
Was thinking pilot ss.
The consensus on here seems to be 245/35 and 275/30
But I can only seem to find 275/35r18 online which is why I was looking at 245/40 and 275/35.
