      05-10-2019, 08:53 PM   #17
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
You didn't indicate whether you're running the M or 3.0i. If the 3.0i, keep an eye on your rear brake pad wear. TC on the non-M is all done through the brakes and your rears will get quite a work out.
Take your torque wrench with you and check torque on all lugs on all 4 wheels between each session. Your brakes and therefore your hubs and wheels will see a lot more heat which can make the lug bolts loosen up a bit.
Top Down 365
jns_e8574.00
