Originally Posted by WangTa
When you guys say "sealer" is that the same as "clear coat"? Getting ready to buy one of these kits and from my research, I was under impression that much like paint - starting with lower grit and ending with higher grit sand paper was in order, then moving to polish and wax - and finally clear coat - was the key?
Yes, in general as you described, but no wax. After the last polishing step, I sprayed on Meguiars G17804 which is the UV protectant.
David
