Originally Posted by crfine88
Thank you!
I like the floor mounts from MS and VAC equally. I went with VAC this time because I prefer the adjustability of their side mounts and took advantage of their package deal for seat mounting hardware. Was able to save a couple hundred dollars overall installing driver and passenger seats.
I haven't run into any fitment issues using the VAC floor mounts withe VAC side mounts. I have the driver seat installed all the way up agains the center console. There is still room to push further toward the console in the mounts.
I did experience what you are talking about when using Recaro side mount with VAC floor mounts. The narrow base of the Recaro mounts combined with the narrow inside VAC floor mount did not allow enough movement toward the center console. MS Mounts are definitely the way to go in this scenario or any other narrow based side mounts like Recaro
Bingo!
I'm using the Recaro side mounts with VAC floor mounts, which you just called out as my issue
Super helpful Chris!
