As I said… have the Carver 10 channel DSP radio system… added the aux wiring to the radio 8 years ago. The Bluetooth harness in the Google results simply plugs into the radio and the wiring harness stacks/plugs into it…. Or the reverse. It's obvious as to what goes where. Much better than the pin connector I got which had to be oriented correctly when plugged into the back of the wiring harness. It was an eBay special ….
The biggest pain is removing the air vents… which isn't that difficult… just a pain in the butt.
All in all a 30 min job first time around.
Sent from my smart phone...
