Originally Posted by mainsoda
Like butter, it gets a little hot but it never sticks like the stock dipstick.
Thanks. That's a plus for the ECS stick. However, your observation about it concerns me a bit to switch over. The ECS stick may be a bit shorter, but if you lay it down side by side with the top end lined up, does the MAX level on both sticks line up? The low end may not matters as much if it is indeed just a tad bit shorter.
