I just got off the phone with Jes at Module Masters. He seems to think it has to do with voltage/current (not enough). I only have it hooked up to a 2A charger and my car turns on the headlights/tail lights even if the switch is off.
At the moment, the car is only storing a 5DD2 (Hydraulic unit adjustment, DSC unit (valves)
It will not pass the calibration of the DSC unit, the motor turns on for a few seconds and tells me the adjustment could not be performed.
I have bled the brakes multiple times using several methods to no avail.
I have a cable and can modify the pins if needed, just not comfortable with learning new software.
If there is anyone is in Alberta, Canada, and already knows/has this program.
I would be happy to pay for your time.
Tye
