Originally Posted by intoflatlines
Thanks for the info. Does the si share any suspension components with the M?
Might be a couple of flat washers that are common, but otherwise not much LOL. The Z4M suspension is derived from the E36M3 while the other Z4s are from the E46. My car came with the M Sport suspension, but the only parts I still have on the car are the springs and the rear sway bar.
One thing you can work on that will help is getting off the brakes before you're cutting into your turns. If you're braking and turning you've doubled the dynamic load on the front tires. You can roll through turns faster than you can brake and turn.
Do you left foot brake? If not, you should learn how to do it, as it can shave quite a bit of time off your autocross runs.
