Originally Posted by XMetal
You may want to check your rotors to make sure they are installed on the correct side of the car - they appeared to be spinning in the wrong direction
I appreciate your concern, but that only matters depending on the fins on the rotor. If the fins are straight in as these are the slots can go either way. If you have curved fins then the direction does matter. Just FYI, thanks anyways,
