Originally Posted by Twisted Six
When restoring my 240-Z I used 3 rolls of Dynamat against the sheet-metal in the entire car. That included inside the door cans, upper and lower roof, B-pillars,quarter panels and fender arches in the rear. I also did the inner walls of the hatch as well as outside the car just above the muffler and exhaust tubing under the car.
Result ?? Huge difference in the interior decibel rating reduction. I could now drive the car with windows down at 90mph + and speak to a passenger with a non-strained voice.
Penalty= about 9lbs. But I could shave that with CF parts no problem.
I actually have a Decibel meter and will attempt some 'before & after' testing when I do the same to my Z4 coupe.(maybe this Winter).
I don't think anyone should worry about adding 9 lbs of weight to their car. Better that the driver should lose weight if you want better performance from your car...and your body.
