      11-23-2018, 04:59 PM   #83
GuidoK
#buildnotbought
GuidoK's Avatar
10871
Drives: Z4 3.0i ESS TS2+
Originally Posted by Michael9218 View Post
Pic of the failed driveshaft center bearing carrier. The driveshaft was a tad too long when I got it back from the driveshaft shop. Lesson learned. I gave them an amount to take off, but didn't take a final measurement. It fit, but was tight. This apparently put too much stress on the rubber webbing that floats the driveshaft.
So how did you notice that the driveshaft was too long? (when you say it was a tight fit).
Normally the drive shaft is 2 piece with a splined section that can vary the lengt a bit.
Was the splined section completely retracted (pushed in) when you fit it to the car?
And did you notice vibrations while driving?
