Good to see you here Sia!
Had a great weekend zipping around with the ///M! I found a good tip - if you want to get the 3D 'perspective' view for the nav... on the main menu go into 'set' and then hold 'menu' button for ~10s - it will open up a new menu with VIN number etc. You can turn perspective on in that menu and then it will come up as an option on your nav.
Best thing I found about the car this wknd!... O and that it is ridiculously fast!
Dave
