      09-08-2019, 01:13 PM   #6
3002 tii
3002 tii's Avatar
2286
Originally Posted by rsutoratosu View Post
I bought these last year due to youtube videos review, brightest bulb reviewed.. not sure if theres anything newer. & better I have a 17 mdx and those new led are bright... now they almost matched..
My issue is I start getting fog in the headlights... so I need to take the right side out and refit the area.. dont know which step I didnt' close up correctly
You should consider replacing the main rear headlight covers. The seal/gasket dries up over time and once you take it off, it won't have same tight seal even with the clip locked on. This happened to me few years back on my n52 coupe so now I always replace those covers whenever I do a bulb swap every few years.
Obviously you should wait for the headlights to dry out before you swap the covers but you get the point.
Follow for latest mods
