Originally Posted by abelgonzaleZ4
Windshield rubber trim arrived yesterday and now installed.
Took me about 15-20 min.
Some areas were tough with warping so I used a plastic spatula to lift it and pull and push the trim down for a snug fit.
Cleaned up nicely at the end.
Looks good! I purchased the same thing and did the install last weekend. I had to cut about half an inch of the existing rubber stripping all the way across to level out the areas that cracked off. I also ended up taking off the cowl to install. I was having a hard time raising the cowl enough to slip the rubber piece on. It looks way better than the cracked mess before.
