Originally Posted by mattfwalters
Added ATF to the power steering system and manually moved the rack back-and-forth a few times. I'm sure it needs actual bleeding but oddly enough have never bled a power steering system before, so need to figure that out. Advice about this process / BMW PS racks
The system is self bleeding. Just turn the wheel lock to lock several times with the motor spinning the pump. Top with fluid if needed.
